@z06 Thankyou sir
@splfanatic:
Sir, Basically no Solid Audio amp available is original. The company Solid Audio no longer exists, they are out of business for many many years. Their web site solidaudiousa.com is no longer operational and you can not find any solid audio product on any international online store either.
The solid audio available here are Fakes or perhaps copies of the original amps but not manufactured by Solid Audio anymore. I wont count on these fakes/ copies.
Now about the Original Solid Audio Amps; even they are way over rated. They were inefficient i-e they needed more current to produce equal amount of power compared to newer tech amps. The board used and the circuit designs used by Solid Audio were generic and conventional, not high tech design, just basic, which were used by many other ordinary brands. I have reason to believe that even original Solid Audio were way over rated and in turn they are not cheap, in fact you are paying more and getting less. If you calculate Rupees per watt, actually you are paying more per Watt compared to the main stream branded amps.
Now if thats the case with the original Solid Audio amps, you can understand what might be the case with these so called Solid Audio Amps
If budget is the issue i wud advise rather to buy fusion instead of Solid Audio.
@realplaya Yes Sir both of the amps you mentioned are very good amps.
