What the heck is weights and spray they are doing every service?
Following is must. Rest you can ask them if facing issues
Rest should be as per requirement only .
I think spray is the one they use for servicing the throttle body and weights are for wheel balancing.
yep definitely going to get all these changed. Just wanted to get an opinion if the fuel filter can be skipped.
There is zero mention of cleaning the throttle body in Hondas own service manual.
Overcleaning actually damages the throttle body.
yes i agree with you and that's why I only get it done once in about 100k kms
Why are they changing irridium plugs at 40K kms?
no they are not. Just mentioned in the list.
multimedia of civic 2017 is blank now, i made a hard reset then i was working later on again it stopped working, can you please tell me the possible solutions?
AOA. I have Civic Oriel 2018 Model. First owner. I belong to Rawalpindi. Today i found that AC is not throwing Cold Air. Called Honda OEM, they are telling that there can be issue to Evaporator Coil Replacement. But before proceeding for it; they will carry out few checks for leakage in joints etc at Engine Bay Area. May be they will refill with UV dye and give car for testing. They charges for every diagnostic steps. Pl. share your experience of AC leakage, rectification. Is issue of leakage from Evaporator is common. Looking for your suggestions / advices. Regards.
Its a common issue in Civic X, the only rectification is replacing the evap.
anyone in Lahore willing to let me make a copy of their SD card containing Sygic navigation data?
Should installed Honda OEM Evaporator (Made in Thailand). Any one has experience of FORMULA Company made equivalent Evaporator (Made in Thailand). The approx. price difference is Rs. 8000.00
go for original one.. after market are subpar and poor in cooling, experienced myself. After market shit and waste of money.
OEM was like 35K i guess or now maybe more
Thanks for response. As advised; I will go for OEM Evaporator (Made in Thailand). The current price is 29500.00. Pl. also advice that installation should be thru 3S dealer since dismantling of dashboard is required for replacement of evaporator. 3S service charges are high Rs. 29000.00 (Labor)+ 10000 (Gas). Local AC Service shops demanding 10,000 for installation and some says that these charges also includes gas. I am not sure about quality of work of local shops and the Gas they will charge in system. If there is some very good AC Shop / technician in Rawalpindi then pl. advice.
I installed an aftermarket evap, chinese made. Its been two years and its holding up pretty well. I felt no noticeable difference in cooling as well. Got it replaced from a shop in Lahore. 3S charge too much.
dont go for after market, i am myself victim of it.... what i heard OEM has exact no of jalis or what we call it..
It is one time cost and spend on it.
Better to go with 3S they have machine to recharge the gas, i saw at Honda township and ringroad.
During weekend, I visited Honda Avenue Islamabad. They carried out pressure test to check the leakage at 300 PSI. Pressure dropped and sound due to air leakage was noticed from central Air Vents. I also noticed that sound too. They informed that Evaporator has leakage and needs replacement. I already had made my mind that if evaporator is found leaked then i will installed HONDA Genuine one since reviews of after market evaporators were not found satisfactory. I also felt that HONDA must has made improvements in evaporator due to issue of frequent leaked evaporator of 2016-2018 models of Civic X similar to improved steering problematic part. Honda Avenue staff was found very cooperative. They offered very good discount on Services and Gas Charging. Removed dash board and replaced evaporator, charged gas thru machine. All work completed in Rs. 55,000.00. No sound has been observed from dash board due to fit up and AC is working perfectly. If it would have installed GENUINE Evaporator thru road side mechanic / shop then i could have save Rs. 10,000 only. Work thru HONDA Dealer ship is piece of mind with warranty on part and services. Oil marks were found on outer surface of old evaporator that indicates leakage of refrigerant with compressor oil. Regards.
Bump
Hello. My Civic's ECU is dead. Is there anyway it can be repaired because Honda is quoting 225k and a weight time of 4 months. If anyone can recommend a good workshop it will be great. I live in Karachi.
