nothingits normal don't worry about it
Get the suspension bolt tightened by Honda . I once faced this and it went away when they tightened the bolts of suspension and body joints underneath
So im assuming there was no reoccurrence after ?
Bro which cloth do you use? for waxing and washing the car if u can specify
Yes no reoccurrence yet
Thankyou il get it done and update .
What to do when remote startup doesn't work? It stops after first sulf.
Bro..be sure that this noise doesnt come from the steering.....faulty steering box is very common in Civic X.....closely observe and if this sound is linked with steering movement then its from steering box definitely which can be claimed easily coz its a known problem to Honda.....as far as i know nobody has faced a suspension issue in X no matter how rough he has driven the car....
This is the sound of control arm bushes.... They came previously in my Honda City while passing and breaking on a speed breaker unintentionally accidentally which exerted more weight due to momentum and link arm bushes started squeaking..The car was just driven 15k kms and dealership was not able to find it despite dismantling complete shock absorbers... although its not good for i guess rubber parts but i diagnosed by myself and used to spray WD 40 on the 2 +2 bushes left right..... The squeaking sound used to disappear for 2/3 months or so...Usually in winter one needs it freequent due to bushes getting hard in winter than in summers... i sold the car at 94k kms and the bushes got no harm due to wd40....
advise the same.....
NO over torquing brother! ya can be cross checked for tightness .... but usually its not the cause of squeaking bushes....
Check main batt if it cranks low and do not start
Bro, iv heard about the steering issue , apparently its the steering stem that crackles but Allah Ka Shukar its not the steering in my X .
Thanks for the feedback . Im writing down all possible issues that could occur. Il get the bushes checked aswell on my next service. Just waiting to get an appointment from Honda SITE so i can get this sorted .
But it starts normally when push start button is pressed on the dash.
then remote batt probably
When i release the remote startup button after 5 seconds the car lights blink and engine cranks but gives up after first slight sulf.
Just about the lowest quality/lowest end 'made in Japan' tire you can get.
True but in my case I personally saw two points which were not pre torqued and after giving it required input, it vanished .
@AdnanAhmedButt sell the Civic and get a Grande
.... i think i know you
