I specifically asked for it during last oil change but they didn't have it.
One more thing, when air filter replacement needs to be done? In 2 oil changes they just cleaned it. I'm going for a new air filter at next oil change whatsoever. But I thought that air filter will be changed at 2nd oil change.
Toyota oem Air filter must be changed at 10,000kms
the car i am talking about is a suzuki and its oem filter is also guard fortunately or un fortunately :(.
Yaar? Koe Allah ka banda suzuki k ceo ko chittar maar day
But news channels are saying that price will drop upto 4 Rs in September.
Confusion hi confusion......[emoji53]
also 20W-50 also means 50 viscosity which is being put by default by all dealerships so its simple a synthetic is better than mineral any day no questions. even Xulfiqar would back it up.
and rest 5w-30 fully synthetic is good. but if u ask me if u go through start stop traffic on ur usual commute every day option for 5w-50 would be a safer choice.
Acha yaar synthetic walay bhai aap synthetic chalao, hum mineral k saath khush
Tauba.. God save us from the worst brand known as guard filter. They are made to kill Engines.
Sent from my SM-N920C using Tapatalk
by the way a pakwheeler senior member did a filter test sometime back and guard proved to be a good quality filter with proper filtering mechanism and materials used whereas the Leppon (so called malaysian) was totally rubish.
both filters were cut open and analyzed to check. u can search the same on pakwheels to verify too.
Guard original is great buy from Metro
Btw I quoted that on Pakwheels.My oil shop guy did that test.
I tried it once in my corolla 2od saloon. It was original. The engine was begging for mercy. Fuel efficiency declined and pick was lackluster. Bus tub sai i avoid guard products.
Probably you fitted a fake one.I'm using it in my gli with mobil super from last 100,000km @thinking 150rs wala filter itna bhi bura nae waisay
I used it quite frequently on my Xli for some years then moved back to original Toyota, but it performed well.
Vitz 2SZFE 1.3 would be so much happier, faster and smoother :). Shukar AL HAMD U LILLAH.
Also good news for Honda guys especially the turbo ones.
and probably toyota engines will also produce slightly more hp and would have smoother ride.
My Mehru clocked 126k. Using guard filters. No engine issues till date, Alhamdulillah.
Suzuki sells guard as OEM filters
Some more details about 92 rons
http://dailytimes.com.pk/islamabad/19-Aug-16/cleaner-more-efficient-fuel-approved-for-use-in-pakistan-by-ecc
Phir wo fake hi tha [emoji14]nonetheless I still think that best one is original Toyota. It's peace of mind. And has never let me down.
