heat the brass shaft till it starts to blacken.. as soon as it blackens quench in water.. this process will anneal it
straighten the bent part carefully using a stiff card or something in the cut as leverage / reference
attach some rubber to your pliers jaw so you don't scratch or damage
once done clean it up and let it rest for a few min
find a hole / make a dye in which the shaft goes in flush..set it as level as possible and tap it's fat back with a mallet lightly.. idea is to compress it so that it hardens. do the same with the key side making sure you don't bend it (of course)..
I've done this once on an old clarion radio and was a successful endurance. many thanks to the information available over the internet
