..moving on..
I shared with you the pictures of the poorly repaired side of the Oval and my decision to 'slaughter' or 'sacrifice' another bug to harvest the panels required. Arshad did a lot a calculations and marked the lines on the oval this time so the offending panels could be cut out for removal. It is a delicate task, one that requires precision and dead accuracy. My input in the process was almost that of an observer. We did however agree that the original joints would be preserved to maintain the authenticity of the structure. To get as close to original as possible the donor car selected was a 58 rag top. Even then there are the minute differences in measurements that were taken into account and adjustments made as to where the cuts and welds were made.
I would have liked to have a Mig welder handy but unfortunately we could not find one and had to rely on the gas torch. The problem with a gas torch is the heat it transfers to the surrounding area that can warp the sheet metal. We used almost a dozen tins of paint stripper to avoid this issue but at the welding stage we had to improvise and rags soaked in water were placed around the area being gas welded to prevent heat travel. In addition to the wet rag solution Arshad used the dolly and hammer every few inches to ensure that the sheet metal was not warped even in the close vicinity of the weld.
The progress is painstakingly slow but the whole panel was welded in a day. Check out the pictures to appreciate the work of a master panel beater. The oval now has a complete new section with hardly a sign of accident damage.
The inner layer/ frame of the body would be left un-welded until all the panel beating is done and a primer applied. Irfan -the painter would then check the surface for any imperfections and advise. By leaving the inner crust unwelded, Arshad would have free access to make good any flaws.
The pan was restored before I bought the car and it had been left to rot without any protective treatment. I have decided that we would re-do the pan before treating the pan with POR -15. However for now we concentrate on the body work as having a rigid body (attached to the frame makes it easy to take accurate measurements, cut and weld.
