continuing with the details on the pella - engine bay
altogether, its a mess which seems to have resulted from years of neglect and incompetence of the guys who have attended to it
engine block itself is original to the car. chamber/oil pan is leaking, so is the top cover. engine itself looks to be in good compression and there is no blow too though i still have to confirm it using a compression gauge. oil levels are all good too
slapped on with a datsun carb (i believe), the mileage on the OHC is a bad one. could be lot better with a proper nikki carb and tune up. CNG installation must have had its effects too, to what extent, i still need to check as well. alternator is an aftermarket unit and is not mitsubishi. looks to be honda?
original air filter housing has been swapped out for an aftermarket unit to accommodate the CNG kit venturi. a hack which is currently being reversed as sourced some original factory capella air filter housing in australia.
coolant reservoir bottle and radiator both are missing caps. radiator would preferably need a replacement. fuel pump is mounted on the pass side at the inside wheel well - wrong location as it should go in the boot. also the fuel pump is an aftermarket unit and is not mitsubishi
wiring in the engine bay is another mess that would need careful correction. battery box is missing altogether and will need to be sourced
more on the engine bay when i get to see everything in detail
and some pics of the original factory capella air filter housing that has been sourced with a borrowed pic to show how it would look once installed
brake booster looks to be original though i am not quite sure. will need more r&d. brake oil reservoir however, doesn't look original i am not so sure either about the cylinder if its original
