System compatible with which SETUP OF EE90 4WD? Can you please explain a little more about how ABS system works with car ECU, either the ABS ECU works independently or it has to coordinate with car's ECU? Which braking system is more compatible or best for current 1NZ-FE AE90 setup, either Corolla X (because wiring is of Corolla X) braking system or AE101?
I think every car without ABS will lock its wheels and slip. AE90 GT comes with 4 wheel disc brakes, does it also lock wheels and slips??
In your previous post you said that......."If You Find A Whole Complete Set Including Prop. Valve Line Set Hand Brake Cable And Complete Caliper Kit..Then Go For 4 Wheel Disc...Otherwise Avoid It."
If I can't figure out ABS than bigger rotor upgrades is the last option.
