@Kamran Bhai
i am planning of swaping my MKIIs engine. need your suggestions and expertise.
i have short listed few engines, sending you the details. Can you plz suggest me an engine with minimum consumption with appropriate power required for MKII.
1AZ-FSE
Displacement: 1998
Engine model: 1AZ-FSE (D-4)
Max.power (Net), kw(PS)/rpm: 152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 20.4 kg*m (200.06 N*m) / 4000 rpm
Power density: 10.39
Fuel system D-4 (inside the tube directly fuel injector)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio: 9.8
Bore, mm: 86
Stroke, mm: 86
Fuel consumption at 10-15 modes, l/100km: 7.9 (in 1580kg vehicle)
IG-FE
isplacement: 1988
Engine model: 1G-FE
Max.power (Net), kw(PS)/rpm : 160 ps (117.68 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm: 20.4 kg*m (200.06 N*m)/4400 rpm
Power density: 9
Engine information: VVT-i
Fuel system: EFI (electronic fuel injection)
Turbocharger: No
Fuel type: Unleaded regular gasoline
LEV system (Low emission vehicle): No
Compression ratio: 10
Bore, mm: 75
Stroke, mm: 75
Fuel consumption at 10-15 modes, l/100km: 9.6
4S-FE
Displacement: 1838
Engine model: 4S-FE
Max.power (Net), kw(PS)/rpm: 120 ps (88.26 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 16.5 kg*m (161.81 N*m) / 4600 rpm
Power density: 10.5
Fuel system : EFI (electronic fuel injection)
Turbocharger: No
Compression ratio: 9.5
Bore, mm: 82.5
Stroke, mm: 86
Fuel consumption at 10-15 modes, l/100km: 8.1
3S-FE
Displacement: 1998
Engine model: 3S-FE
Max.power (Net), kw(PS)/rpm: 135 ps (99.29 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 18.5 kg*m (181.42 N*m) / 4400 rpm
Power density: 10.3
Engine type: Serial 4 cylinder DOHC16 valve
Fuel system: EFI (electronic fuel injection) (Ci . (central injection):
Turbocharger: No
Compression ratio:
Bore, mm: 86
Stroke, mm: 86
3Y-EU
Displacement, cc: 1998
Engine model: 3Y-EU
Max.power (Net), kw(PS)/rpm: 97 ps (71.34 kw) / 4800 rpm
Max.torque(Net), N*m(kg*m)/rpm: 16.3 kg*m (159.85 N*m) / 3800 rpm
Power density: 17.42
Turbocharger: No
Compression ratio: 8.8
Bore, mm: 86
Stroke, mm: 86
Fuel consumption at 10-15 modes, l/100km: 12.3
Currently i am running on 3C turbo (diesel) pretty much satisfied with its pickup and power. but its getting expensive and expensive to run on diesel.. i want some engine with more or less same power with minimum consumption.
specs of 3C are as follow.
3C-T
Displacement: 2184
Engine model: 3C-T
Max.power (Net), kw(PS)/rpm: 100 ps (73.55 kw) / 4200 rpm
Max.torque(Net), N*m(kg*m)/rpm: 22.0 kg*m (215.75 N*m) / 2600 rpm
Power density: 18.2
Engine type : Serial 4 cylinder OHCIC turbo
Fuel system : Bosch type distribution type (jet pump)
Turbocharger: Turbo
Fuel type: Diesel
Compression ratio: 22
Bore, mm: 86
Stroke, mm: 94
Fuel consumption at 10-15 modes, l/100km: N/A
or if you think there is some other better engine, do let me know.
thanks,
