going against law of physics?
no civic law exists - but nature has several. LOL
law of physics says gravity pulls you to earth - you can challenge it and jump off a building.
should I tell you the result?
similarly - thinner aka low viscosity liquids flow better and better/higher rate of flow nets better cooling - (its a bit similar to having a large reservoir of liquid which acts as a heat sink)
In our case the rate of oil moving in the bearing goes up with lower visc/thinner oil.
classic example is automatic transmission. in some vehicles manufacturers just increase the sump capacity to net better cooling as the total volume of the transmission oil increases.
