2jz engine with Pardo 1994 auto Gear box which will entertain 4x4 as well.But I think this Pardo auto is not 5 speed?4 speed maybe!!!
With Pardo auto gear and 4x4 plus 2jz engine fitted cost is 150000rs.
Engine cost is 65.. Non turbo.. For 2jz.. Gear box at max will cost 30k.
Sent from my C6603 using Tapatalk 2
I think it's turbo one from Lahore and gear is we are using from Pardo which will allow 4x4 to perform.
Me going too for 2jz-ge with Pardo auto gear which will support 4x4 as well
Swapped 1jz Sent from my C6603 using Tapatalk 2
Looks big
Its one of the cleanest swap i have seen. I was very happy with the mechanic and electrician.
Mine in process too once done will post photos but I am having auto Pardo gear with 4x4 as well.
hican u give me the details of ur mechanic .where is he located?looking for some one to swap the same engine in my 1969 w114 mercdrop me a text if possible0336-5105210
congrads on the nice swap do share the power. speed and the milage
Congrats! now please give us the feedback on this combination.
I have not tested mine yet still in the process
best wishes for your project.but if you to go for a complete half cut for this swap than things will be pretty more good as wiring will be a critical issue. also its a high Rev engine which not recommend for off Roading . which LC gear box you are going to use ? and which diff ratio you will be going to opt ?
happy Motoring.
