Hello!
here are some specifications which i find out....
Toyota 4AGE 20V...
Engine model:4A-GE
Engine type:- Serial 4 cylinder Twin-Cam 20 Valves
Displacement in CC's:-1587cc
Tranny:6 speed manual.
Max Power-Kw(PS)/Rpm:-165ps(121.36Kw)/ 7800 RPM
Max Torque-N.m(Kg.m)/Rpm:-16.5kg.m (161.81 N.m)/5600 RPM
Compression ratio: 11
Bore in mm:-81
Stroke in mm:-77
Honda B16A
Engine model:B16A
Engine type:-Water cooling serial 4 cylinder DOHC 16 valve
Displacement in CC's:-1595cc
Tranny:5 speed manuals.
Max Power-Kw(PS)/Rpm:-160ps(117.68kw) / 7600 rpm.
Max Torque-N.m(Kg.m)/Rpm:-15.5kg.m (152.00N.m)/7000 rpm.
Compression ratio:10.2
Bore in mm:-81
Stroke in mm:-77.4
so from this you can conclude out winner..its all stock........i think 20V is gonna take a lead with flying colors...B16 getting its max torque at 7000rpms....whereas 20V geting more than that in just 5600rpms...compression of 20v is bit higher....20 valves 3 on inlet makes much difference also...fo i think 20V no doubt is better than B16....6 Speed Gearbox is gonna make much better ratios than 5 speed....so what you want else....
Thanxxxx
