You can do it yourself. . Brake pads , Injectors cleaning, fuel filter if chocked, plugs and air filter, oil , oil filter, alignment ( see tire wear out). transmission oil should be fine. its too early, you see level is correct, power steering oil level, Boots, ( axle rubber covers), see under engine shield is secured proper, belts have no loose thread, wear out is even, tension is correct, do you have ac filter in yr car, if yes, clean if no, forget it. any other abnormal behavior you can ask.. if you feel like this was information worth some money, you can send check to me via pakwheels addressed Levin.:). thankyou
