Sorry GG for the late response....
This was toora boora exploration trip of G-4 and rally runs were real fun. MMC's turbo were engaged? as soon as it heard the sound of EVO running side by side (H) along with lots of Cruisers and Jeep thing
We discussed all the technological advancements in automobiles industry had in past 70 years and what possibly it could have done till now, here's a quote from one of our conversation:
MMC is parked between the the rides, and Mr. JANJ is giving instructions.
JANJ: Attention boys, this is a straight run passing though that mud and water, a Jay will placed............So boys, I don't have a Tissue to drop to give green signal to drivers for dragging, so focus on my fingers and when u see three then this means run!
Conversation Inside the Cabin:
Basharat: @MMC, boy please turn Traction control on, we don't want to waste inertia in the drag
MMC: Check
Basharat: @fihsak, I have assigned a short code to each shock on the 4 wheels, so you just have to write the pressure in numeric PSI value and send them to shocks as per track requirement, rest is automated
MMC: @Basharat, I told you put this setting on voice recognition system, this saves time, how will it work if we don't have mobile phone coverage?
Basharat: @MMC, fihsak has Thuraya, dont worry Guru Gee our lab is preparing sensors which will auto adjust shock pressures as per terrain with a lag of 20msec...
Fihsak: (A)K, message sent to Palwashay
DD: Abay palwashay ko nahee, shock k short codes per bejh
MMC: @DD, should I turn rally mode on?
DD: Nahee assi ithay bhangra pana hey
MMC: Ok
Basharat: @DD, Nitros were installed last night
, its button is integrated with your blue-tooth earpiece, just push it once you feel its necessary
MMC: @basharat, we forgot to turn-off the hybird mode and engine configurations are showing 3 cyl on the dial, damn I hate this onn & off technology, I want a read my mind kind of thing...
Basharat: @MMC, this was automated last night, throttle will engage the remaining cylinders and turnoff the hybird mode, Pls do check the air pressure in your rally suit, we will be hitting lots of G-Force and your blood pressure should also stay normal...
