h2Command-Trac IIĀ®/h2
Command-Trac IIĀ® supports the new MP 1522 two-speed, part-time four-wheel drive transfer case, featuring smooth operation, shift-on-the-fly capability, and improved NVH control compared to systems with mechanical linkage. 2WD High is the usual driving mode, with the front driveline disengaged from the transfer case and power directed to the rear wheels. Selecting 4WD Lock via the electronic, console-mounted switch locks the front and rear driveshafts together; the two then rotate at the same speed and provide a 50 front/50 rear torque split, providing better traction on slippery surfaces. This transfer case allows for 2WD, 4WD high-range and low-range as well as neutral.
Command-Trac II is standard in Jeep Liberty
[code1][/code1]
style type=text/css"/style
