This is just a banner, the amp itself is brand new but of 2008-09 model
[I]Intake series amplifiers from Audiobahn's. Each amp is equipped with an air induction cooling fan to keep the unit running cool for hours. On-board, cobalt blue digital voltmeter. An optional remote bass control and remote-mount volt-meter display module are available separately.
Key Features:
1200W Max , Intake Series 4-Channel Amplifier
RMS Power Output:
75 watts x 4 chan. @ 4 ohms
150 watts x 4 chan. @ 2 ohms
300 watts x 2 chan. @ 4 ohms Bridged
Max Power Output: 1200 watts @ 2 ohms
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Non-regulated Power Supply
Semi-double Sided Glass Epoxy Circuit Board
4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
Air Induction Cooling Fan
Soft Start Circuitry
Cobalt Blue Illumination
Speaker level (high-level) inputs
Preamp outputs
Nickel-Plated Block Terminals
Bass Boost Control: On/Off (0 or +18dB)
Optional Remote Bass Control (Audiobahn ABR100T VERSION 2 sold separately)
Digital volt-meter display on amplifier
Variable Low-Pass Crossover: 50-120Hz
Variable High-Pass Crossover: 50-750Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
Variable Subsonic Filter: 20-50Hz
THD: 0.02%
Input Sensitivity: 200mV-8V
Dimensions: 9-7/8"L x 11-1/16"W x 2-1/8"H
[/I]
