The replaced sensor is ok as i confirmed from the electrician before installing it. Everything seems connected properly but not sure. Do let me know how to reach you or your workshoop with car to getvit examined.
The ABS problem is fixed after changing the front Hub Bearing which was damaged.
What was the fault code?
I am not sure about the code but Yellow ABS light was continuously shown. Now after fixing the Hub Bearing its fixed now.
