FORD 3610
Production years:1982 - 1983
Tractor type:Farm/Agricultural tractor
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Production:
</TD></TR><TR><TD class=tfld>Manufacturer:</TD><TD class=tdat>Ford
</TD></TR><TR><TD class=tfld>Factory:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Total built:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Original price (USD):</TD><TD class=tdat>$14,500 (1983)</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Engine:
</TD></TR><TR><TD class=tfld>Fuel:</TD><TD class=tdat>diesel
</TD></TR><TR><TD class=tfld>Aspiration:</TD><TD class=tdat>natural
</TD></TR><TR><TD class=tfld>Cylinders:</TD><TD class=tdat>3
</TD></TR><TR><TD class=tfld>Valves:</TD><TD class=tdat>6</TD></TR><TR><TD class=tfld>Bore/Stroke:</TD><TD class=tdat>4.40x4.20 inches [112 x 107 mm]
</TD></TR><TR><TD class=tfld>Displacement:</TD><TD class=tdat>192 ci [3.1 L]
</TD></TR><TR><TD class=tfld>Power:</TD><TD class=tdat>47.5 hp [35.4 kW]
</TD></TR><TR><TD class=tfld>Power (gross):</TD><TD class=tdat>49.7 hp [37.1 kW]
</TD></TR><TR><TD class=tfld>Cooling:</TD><TD class=tdat>liquid
</TD></TR><TR><TD class=tfld>Coolant:</TD><TD class=tdat>11 qts [10.4 L]
</TD></TR><TR><TD class=tfld>Compression:</TD><TD class=tdat>16.3:1
</TD></TR><TR><TD class=tfld>Rated RPMs:</TD><TD class=tdat>2000
</TD></TR><TR><TD class=tfld>Torque:</TD><TD class=tdat>130.5 lb-ft [177.0 Nm]
</TD></TR><TR><TD class=tfld>Torque RPMs:</TD><TD class=tdat>1400
</TD></TR><TR><TD class=tfld>Starter volts:</TD><TD class=tdat>12
</TD></TR><TR><TD class=tfld>Oil capacity:</TD><TD class=tdat>7 qts [6.6 L] </TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Transmission:
</TD></TR><TR><TD class=tfld>Transmission:</TD><TD class=tdat>Dual-range
</TD></TR><TR><TD class=tfld>Gears:</TD><TD class=tdat>8 forward and 2 reverse
</TD></TR><TR><TD class=tfld>Oil capacity:</TD><TD class=tdat>12.2 qts [11.5 L]
</TD></TR><TR><TD class=tfld>Speeds:</TD><TD class=tdat>With 13.6x28 rear tires.</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Dimensions:
</TD></TR><TR><TD class=tfld>Weight (shipping):</TD><TD class=tdat>3,665 lbs [1662 kg]
</TD></TR><TR><TD class=tfld>Weight (ballasted):</TD><TD class=tdat>6,900 lbs [3129 kg]
</TD></TR><TR><TD class=tfld>Wheelbase:</TD><TD class=tdat>75.8 inches [192 cm]
</TD></TR><TR><TD class=tfld>Length:</TD><TD class=tdat>127 inches [322 cm]
</TD></TR><TR><TD class=tfld>Width:</TD><TD class=tdat>64 inches [162 cm]
</TD></TR><TR><TD class=tfld>Height (hood):</TD><TD class=tdat>54 inches [137 cm]
</TD></TR><TR><TD class=tfld>Ground clearance:</TD><TD class=tdat>13.4 inches [34 cm]
</TD></TR><TR><TD class=tfld>Front tread:</TD><TD class=tdat>52 to 80 inches
[132 to 203 cm]
</TD></TR><TR><TD class=tfld>Rear tread:</TD><TD class=tdat>52 to 76 inches
[132 to 193 cm]
</TD></TR><TR><TD class=tfld>2WD turn radius:</TD><TD class=tdat>10.8 feet [3.3 m]
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Ford 3610 Tires:
</TD></TR><TR><TD class=tfld>Ag front:</TD><TD class=tdat>6.00-16
</TD></TR><TR><TD class=tfld>Ag rear:</TD><TD class=tdat>13.6-28
</TD></TR><TR><TD class=tfld>Ag front:</TD><TD class=tdat>5.50-16
6.50-16
7.50-15
7.50-16
</TD></TR><TR><TD class=tfld>Ag rear:</TD><TD class=tdat>14.9-24
16.9-24
13.6-28
14.9-28
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Capacity:
</TD></TR><TR><TD class=tfld>Fuel:</TD><TD class=tdat>13 gal [49.2 L]
</TD></TR><TR><TD class=tfld>Rear axle:</TD><TD class=tdat>24.6 qts [23.3 L]
</TD></TR><TR><TD colSpan=2></TD></TR></TBODY></TABLE>
3 POINT HITCH:
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear Type:</TD><TD class=tdat>I
</TD></TR><TR><TD class=tfld>Rear lift (at 24"/610mm):</TD><TD class=tdat>1,040 lbs [471 kg] </TD></TR></TBODY></TABLE>
PTO:
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear PTO:</TD><TD class=tdat>live
</TD></TR><TR><TD class=tfld>Rear RPMs:</TD><TD class=tdat>540</TD></TR></TBODY></TABLE>
3610 Serial Numbers:
1982: C682000
1983: C684500
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Ford 3610 Power:
</TD></TR><TR><TD class=tfld>Engine (gross):</TD><TD class=tdat>49.7 hp [37.1 kW]
</TD></TR><TR><TD class=tfld>Engine:</TD><TD class=tdat>47.5 hp [35.4 kW]
</TD></TR><TR><TD class=tfld>Drawbar (claimed):</TD><TD class=tdat>36 hp [26.8 kW]
</TD></TR><TR><TD class=tfld>PTO (claimed):</TD><TD class=tdat>42 hp 31.3 kW
40 hp 29.8 kW
</TD></TR><TR><TD class=tfld>Drawbar (tested):</TD><TD class=tdat>35.86 hp [26.7 kW]
</TD></TR><TR><TD class=tfld>PTO (tested):</TD><TD class=tdat>42.47 hp [31.7 kW] </TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Mechanical:
</TD></TR><TR><TD class=tfld>Chassis:</TD><TD class=tdat>4x2 2WD
</TD></TR><TR><TD class=tfld>Steering:</TD><TD class=tdat>power assist
</TD></TR><TR><TD class=tfld>Brakes:</TD><TD class=tdat>drum
</TD></TR><TR><TD class=tfld>Cab:</TD><TD class=tdat>Two-post ROPS</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Hydraulics:
</TD></TR><TR><TD class=tfld>Type:</TD><TD class=tdat>live
</TD></TR><TR><TD class=tfld>Capacity:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Pressure:</TD><TD class=tdat>2500 psi [172.4 bar]
</TD></TR><TR><TD class=tfld>Valve flow:</TD><TD class=tdat>8.5 gpm [32.2 lpm]
</TD></TR><TR><TD class=tfld>Steering flow:</TD><TD class=tdat>3.6 gpm [13.6 lpm]
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Electrical:
</TD></TR><TR><TD class=tfld>Ground:</TD><TD class=tdat>negative
</TD></TR><TR><TD class=tfld>Charging system:</TD><TD class=tdat>alternator
</TD></TR><TR><TD class=tfld>Charging amps:</TD><TD class=tdat>32
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Battery:
</TD></TR><TR><TD class=tfld>Number:</TD><TD class=tdat>1
</TD></TR><TR><TD class=tfld>Volts:</TD><TD class=tdat>12
</TD></TR><TR><TD class=tfld>Amp-hours:</TD><TD class=tdat>128 (diesel)
77 (gas)
