Hi Experts,
I have alto vxr 2008, The problem is that i had replaced water body about 2 months ago along with thermostat installed because of winters coming. After that i am facing a problem, whenever i go to long route, after some kms on high rpm, radiator starts to throw water to reservoir and ultimately after 200kms, car starts to overheat. Then i have to open the radiator cap and when air escapes from the radiator, then it becomes normal as radiator sucks back the water from reservoir. car is normal in city as it doesn't behave like this nor sucking much water from reservoir in routine, only creates problem on long routes. Kindly advise me but keep in mind following information:
1. Radiator cap replaced
2. Radiator cleaning done
3. No bubbles in radiator whenever i check it with full water level in radiator.
