There is no problem with the air conditioners of Alto, Mehran and Cultus, no matter what you do they will give you limited cooling when they are idle. At 1000 or 800 rpm engine speed the compressor gets very limited power to operate, but when the rpms reach from 2500 to 3000 the compressor starts to work at its max efficiency.
As far as showering the condenser with water, it won't do any good because the designers are well aware of the fact that when you stop at a light your condenser is sucking the exhaust air of the car in front of you. Hence they always design condensers slightly bigger than actual design parameters.
I don't know about the local manufacturers but the cars being used in Gulf have special air conditioners to cope up with the high ambient temperatures of 55 Celsius.
