First of all dear teeboyuk: you really don't need to know the technical details of the cell but you may read the following report (also you listen to music but you don't know how the voice is converted into analogue or digital signal and then back to sound)
Quote "In 2007, the U.S. Department of Transportation issued a final report outlining the use of hydrogen fuel in commercial vehicles. The report stated the use of hydrogen injection systems, essentially an HHO system, could be used to increase mileage and reduce emissions in commercial diesel vehicles.Using electrolysis to create Brown's Gas does work. Most systems use a stack of steel plates that act as positive and negative poles for electricity from the car's alternator. The current, with the help of a salt (potassium hydroxide), rips apart the molecular bonds that hold a water molecule together. The gas is pulled into the intake manifold by the engine vacuum. The gas is either used to increase the quality of the fuel burn, increase mileage and reduce emissions, or replace a portion of the fuel."unquote
Those who think it takes more energy to get Hydrogen from water then the energy itself, are probably not doing it efficiently or correctly. Electricity required by the electrolyzer is very small and easily available by Alternator. Ask auto electrician and he will tell you that alternator only need to do 20% of charging to keep the car running however if you use music system loudly and have all the lights ON then alternator may be working 80%.
One last thing for VCheng : Ediots actually never accept that they are idiots.[/QUOTE]
Wow. I'm amazed. I asked simple question .. The answer I got was totally retarded...it seems u know more about me than I know about my self. If your being rude to someone. What sort of response are you looking for.
So if buy this kit. And use my lights put my CD player on that's playing **** louge the kit won't work.
As far as it goes for Amazon people have to purchase the kit in the first place.
Hho pls provide pics of your kit your contact details so a pakwheels member can check .. So we can get an accurate picture
Regards.
Tahir.
