ok boys i am bak.
Reply By : meer55 on 7/10/2009 3:34:16 PM
salam
i have civic05
kenwood 7037 dvd
solid audio f47
kenwood component speaker 702
problem is humming
try these
1)lower the amp gain
2)ground the rca with the deck body
Reply By : mafzaltareen on 7/10/2009 3:17:48 PM
@enerlevel
i have a query on which i m confused,i know you can solve it.
i have seen an amp whose output figures are given as follows:
2 x 250 Watts @ 4 Ohms
2 x 500 @ 2 Ohms
1 x 1000W @ 4 Ohms
now i want to know if i use the same amp on bridge mode @ 2 ohms what will be its output
mathematically,
1x _____ w @ 2 ohms
technically u will have some blown transistors and a bad output supply..... its 1x1000rms@4ohms. u cannot put it to 2 ohms load mono channel
Reply By : khyberian on 7/10/2009 12:50:07 PM
Bhai yeh Poster kahan chala gaya koi reply nahi kar raha kisi ko, Well here is my question. I am willing to install a good pre with USB Support and Quality Spkrs in my khyber. My range is 3000~5000 max. Plz guide me ????
mai agaya bhAI :D. for 5000 u want quality speakers and good pre....... the range is too less.u will have to settle for china...... try AVT , Vtrek . these are better china brands.
Reply By : geforce on 7/10/2009 11:25:41 AM
i hope u will change from city to Mark X or Camary or may be CL9
if i had to stay in pakistan , i would...........
Reply By : xalmanreyaz on 7/10/2009 10:27:59 AM
@ topic poster
Doctor sahab m using
kenwood cassette pre KRC469with car kit on mp3 player with a 4 ch kingvox amp
running 2 kenwood speakers kfc 6945a 450watts
and a kenwood typhoon woofer w2509 12 inch
on a sealed enclosure in a cng alto vxr
i have the bass to an extent but i need the growling bass
planning to change pre with 4150ub or 4050ub
can this solve the matter or shud i cahnge the woofer or amp and tell me about the speakers
thnx bro
your problem is sealed enclosure.... do it ported or "bandpass" as the local market calls it. u will hear an increase of 3db atleast. 4150 or 4050 , same thing.
Reply By : khay on 7/6/2009 10:19:42 AM
i need to know better speakers den kenwoood 718
you want others to hear? then NONE. if u want urself to hear , then i suppose there are many.
Reply By : civic2s on 7/5/2009 8:42:37 PM
can i connect the stock speakers of civic 1.8 with 1400 watt korean made amplifier along with woofer
try to HPF them and use it with care and they are good to go! yes u can.
dreamgirl:-
have strange problem with my JVC player which comes with Liana....Cassete Player and Radio pe bilkul clear voice ati hai but CD pe aik ajeeb sa shor ata hai aur cassete player pe volume bi high hota hai per CD pe volume bi low ho jata hai...i hope meri problem samajh agi ho gi
Thanx n regards
get it checked , this problem looks more like an internal player flaw.
aamir_s9
hey just need some advice i hav civic 2004 having its original system now i want to change the speakers..so should i go for pioneer components or use 718 ? my range is max 10k..
since ur system is stock , i suggest u get the minimum nominal power speakers. try finding speakers with 40-50rated power. tht should suit u the best.
