Reply By : xalmanreyaz on 8/3/2009 4:37:35 PM
hi enerlvlman
i am using these in my Alto cng with a sealed box. how can i enhance lo bassamp is King vox working gud.... using player with PSP on an cassette adopterdo i chnage woofer , sealed box , player or ampguide manMaggi if u c this i need u too
thnx guys
try to change ur deck.the deck plays the most imp role in quality.
Reply By : qasimdada on 8/3/2009 8:15:01 PM
A.O.A
I have been experincing a very strage problem.. apparently my sound system was working fine.. bt one day i heard some strange sound from one of my speakers and saw smoke.. its coil got burned... i changed the coil and when i put it back, it started making the same weird noise plus the speaker started to vibrate very harshly.. and when i put it to the other side, it was fine..
Wht can be the problem? amp? wiring or speakers?
My Amp is Blue LAser 1500 Watt 4 Channel, And speakers Kenwood 6982,
Plz help..
looks like ur amps gone. get it checked properly.
Reply By : bluespark on 8/3/2009 8:28:34 PM
Salam.,
i Have this problem... Im using Addzest cassette players,But as soon as i turn the switch off,it forgets everything.Time,Radio channels,base etc every setting.,... so that i ahve to reset everything agagin everytime... Thats v horrible... Any solution or should i through it out?...thanx
wrong wiring. get it checked from the person u installed it.
Reply By : khanji_143 on 8/6/2009 1:35:00 AM
Theres a Kenwood KAC-X810D Mono Amp up for sale
hows the performance ? is better then Caliber or any other leading D class amps ?
the kenwood amp is good as long as its working. all the old D class amps use a different mosfet which is not available in pakistan and use a "brain" card which is very difficult to identify the fault.
2) i cant see whats written on the amp. however , gain depends totally on what volume u like to listen to. if u want it to be loud in low volumes , then set gain high. but if u like to crank the volume up to 35-40 , then keep it low.
