Reply By : sufian123 on 9/17/2009 12:06:09 AM
yr mujhe aik problem hai mainne new system lagwaya hai apni hiroof main
718 1 pair
1 308d2
pioneer 7150ub pre
fusion pp-am16004 (1600 watt) amp
per yar base sirf gadhi ke under he rehti hai bahar itni nhi aati kia karoon plz help me
make a bigger box.
Reply By : sma123 on 9/15/2009 12:49:37 AM
i HAVE BOUGHT 2 W308D4 AND RUNING THEM OF A amplifier amarican audio which is 5000 watts 4 channel (i thnks its chines)its says made in korea on it but after half an hour it trips i paid 11000 for the amp.. plz tell me which amplifier will perfectly run my 2 woofers W308D4 plz help!!! i have also put a new batry in i am running a pioneer dvd play tuoch screen the latest 3100dvd smthng and kenwood 718 and also changed the frond door speeks but running them on a difrnt apm sold audio 1600 watts jst help me wid thw woofers amp ... will post my soud systems pics as i get the amp problem solved...
boss i think u called me , and i already replied....
Reply By : sma123 on 9/15/2009 12:43:51 AM
1ST TELL ME WHICH IS BETTER PIONEER TS W308D4 OR TS W308D2 AND .....if i want 2 install a pair means 2 woofers.. d2 or d4 ..??
if u have a 2 channel amp then 2 d4. if u have 4 channel amp then 2 d2 bridged to each channel.
Reply By : automan1 on 9/14/2009 1:51:07 PM
PLEASE PLEASE TELL ME THE SOLUTION FOR
PEDAL NOISE I have done every thing but accelerator noise
is always present ..... i mean when ever da car is start and i RUN MA system DEN dere is na noise and it increase wid da accelerator pedal and wen da car is off AND i run da system dere is no noise ......
wat is da main reason behind dis noise....
if u have checked everything and still the noise is not going , then put the gain down on ur amp, it will help in reducing the noise.
Reply By : 440 on 9/13/2009 11:32:46 PM
@enerlevel
AOA yar i need ur help i got a kenwood pre video walli its only 1 and half year used. i got 4 speakers 2 are kickers 699 and 2 are of kenwood .my car is mehran the problem is when i turn on my headlamps at night + plus A/c etc my pre restarts again and again even if the headlamps are off when i increase the volume to 20 it restarts .Battery is checked and its fine headlamps etc are also fine so wat could be the problem.
regards
shumail khan
it could be the wiring or u have a weak alt. battery is the secondary source , alt. is the main primary source of current.
