Reply By : geforce on 3/26/2009 9:50:35 AM
@ Ener level
thanks ..
@ Question for you ,
My amplifier`s wire gets hot , slight hot , when audio system produces bass , the head light get slight dimm ,
it tells me to use heavy wire like 4,6 gauge wire
but what if i purchase an ordinary bulk wire and make it double from the battery to the amplifer
will my problem solve?
i have seen many systems running on thin wires but they never get hot. check ur battery and ground.
Reply By : geforce on 3/26/2009 7:45:30 PM
@ enerlevel
where can a bandpass box be prepared ?
any specific carpenter u know ?
bandpass is the most difficult box to make. u better stick with ported.
Reply By : booster on 3/26/2009 11:25:08 PM
hey
buddi wantd to know that can i run my sub on 2 ohm and will it give more performance then that on 8ohm on which it is at present???thnx
the service manual for this amp is all crap. the amp is 4 ohms stable. or atleast thts wat i have tested.
