Hi @xulfiqar and everyone,
I have a Mercedes Benz, year late 1999, C180, W202. It has number of electrical problems. The worst problem so far that I am facing right now is to get rid of BAS light which is consistent. I have replaced the brake light switch, steering angle sensor, yaw rate sensor and lateral acceleration sensor.
I connected it with the Carsoft v7.4 code reader. My ESP is ok now and no error codes, however I still have BAS light on in the instrument cluster with error codes B1042 which refers to CAN communication error with BAS unit.
With (ME) I get code P0341.
There were many other electrical problems related to PSE, EIS and Instrument cluster. I got rid of them after I replaced the old AGS battery with Volta MF100. Moreover car heater which was not working before now works fine.
I believed that remaining errors would also go away if I change the Volta battery to some Imported ones like Acdelco and I did that and spent 25000 PKR to buy 100AH , 850cca SMF acdelco. Some of the electrical errors that I got rid of came back again when I connected the code reader.
Now I believe that Acdelco battery is plain rubbish.
Can you please recommend a battery for my Mercedes Benz year 1999, c180?
Battery Specs:
100AH
(L x W x H) 354mm x 175mm x 190mm
12V
hold type B13
