Archi 150cc Origin/True Revelation!
Bike in Pakistan: Archi 150cc
Bike in China: Loncin CR1S and Kuba CR1
(You can watch bike videos on YouTube with these names) https://www.youtube.com/watch?v=jstO2YtoD0M
I was searching about Archi and stumble upon this. The Super Power/Power Archi 150 is based on Loncin CR1S and Kuba CR1 Chinese bikes.
Archi launch is similar to Ravi Derbi and Road Prince Wego. Both Derbi and Wego share the same origin/bike with minor differences.
So now same is the case with Archi which is based on Loncin CR1S and Kuba CR1. I think Kuba CR1 is also based on Loncin CR1S. So the origin is Loncin CR1.
Loncin is offering two models CR1 and CR1S, both are same bikes with few differences such as with Yamaha YBR and YBR-G.
In my opinion Super Power is launching Loncin CR1S model with few changes such as: not black engine, added rear disc brake, added mono shock, no LED lights which are in CR1 headlight e.g.
Did you guys noticed Archi engine was shown in black color in ads but the one launched in our market have silver color.
NOTE: I mean no offense to any bike manufacturer/rider. I'm just sharing these details for info sake only. My info could be wrong and these are just my opinions.
Loncin website is not showing any details and images of CR1S so I'm sharing CR1 and Kuba CR1 bikes.
TECHNICAL SPECS Of Loncin CR1/CR1S
Model JL150-58 (CR1)
Model JL150-58D (CR1S)
Year 2013
Engine and transmission
Engine type Single cylinder, 4 stroke
Displacement 150.06cc
Bore x stroke 62?49.9mm
ompression ratio 9.0:1
Maximum power 11.4hp(8.5kw)/8000rpm
Maximum torque 10.5N.m/7500rpm
Fuel system Carburetor
Fuel control OHV
Ignition system C.D.I
Cooling system Air
Starting method Electric / Kick
Gearbox 5-speed
Final drive Chain
Idle speed 1300 rpm
Chassis, suspension, brakes and wheels
Frame type Steel
Front suspension Telescopic Fork
Rear suspension Dual Shocks
Front tyre dimensions 80/90-17
Rear tyre dimensions 110/80-17
Front brakes Disc
Rear brakes Drum (Disc in CR1S)
Dimensions and Weight
Overall size (L?W?H) 1990mm?785mm?1050mm
Wheel base 1290mm
Seat height 770mm
Ground clearance 170cc
Dry weight 125kg
Maximum load 150kg
Fuel tank capacity 15L
Other
Maximum speed 100 km/h (YouTube videos are showing more speed)
Battery 12V 7AH
Turn light LED
Taillight LED
Meter LCD Digital
TECHNICAL SPECS Of Kuba CR1
ENGINE
Volume 150.06cc
Engine Type 4 Timed
Cylinder Single Cylinder
Maximum Power 11.4 Hp 8000 rpm
Fuel System Carburetor
Ignition CDI Ignition
Cooling Air Cooled
POWER TRANSMISSION
Driving System Standard
Front Brake Disk
Rear Brake Kampana
SUSPENSION
Front Double Telescopic Fork
Back Helical Spring Double Damper
Front Tire 80.90-17
Rear Tire 110.80-17
DIMENSIONS
Length 1990 mm.
Height 1050 mm.
Width 785 mm.
Axle Distance 1250 mm.
Empty Weight 125 kg.
