@Xulfiqar i tested the connection on that pin till fuse box connector.
Tested Following1. Switch is fine
2. Tested contunity between switch wire and pin you mentioned. It is fine.
3. Tested that pin for contunity with ground. On door open it shows that pin is at ground and not otherwise.
I guess that everything is fine now blame comes on MICU
What do you say if that was faulty it would not work for other doors but everything works fine. I am getting honda HDS cable on monday InshAllah.
I tried to jump with the connector as shown in manual you gave. I could not find space to insert that connector on fuse box
which one is it one with two pins as in following pic
Is it that place where no connector is plugged?
On honda-tech forum they are suggesting it may be faulty MICU
