you are seeing a good functioning system, the compressor discharge pipe is always blazing hot, the refrigerant is heated up as its squashed together, the condenser cools down this refrigerant. So if you experience a large difference of temperature on inlet and outlet of condenser then the condenser is working.
If the system cannot pull down the vapour line pressure effectively, and you feel the compressor is lugging badly and have a low reading on the high side port then you have a blocked condenser scenario - in that case you will also experience the high pressure safety switch on the compressor kill it (switch it off) and vent the refrigerant at the same time.
For oil, buy the ND bottle and flush out the compressor too by pumping all the old oil out of it. Fill at different spots to prevent oil slugging.
I have also seen the "finger pressure test" on compressors - which is BS, I dont think any human has fingers to test 200 psi pressure or even the hand dexterity to spin the compressor to 1700 rpm.
