Sir please advice how to make this engine stable and low on vibrations as it often breaks 2c mounts or the metal sheet on the back side mount and that is original to the cross member, front one is moded, all mounts take are only good for a year.
i recently readjusted engine to make the axles straight, but still a bit adjustment is required as the bolt holding the back moded plate for 2c mount got broken inside and now only running on only one bolt that is on block at the rear end of engine. and put a nut in front 2c mount to make engine straight.
sir is this engine side mount capable of holding all of the engine weight? if not what would be best option here, i have some tools i work at home.
please enlighten me with your knowledge.
