check the body structure everywhere for repair/damage - open and close the doors, test drive the car and try to nagivate slowly on uneven road - like climbing a driveway, if the body creaks or you hear odd sounds, then most probably the car is a gone case.
Checking the engine is easy. it should start sweetly, run like factory spec meaning, no direct running radiator fan, it should be getting fully warmed up (half gauge) - and have no issues pulling the car and should not be making odd noises or blowing smoke or leaking any oil from anywhere.
If you see tell tale signs of "deezal sarviss" in engine bay - make a budget to replace all the wiring/plastics/rubber in the engine bay in the future.
The suspension and brakes are almost bound to be bad unless they can prove it to you that it was repaired professionally and not with "ustaad ka haath and aaloo ki grease"
