@xulfiqar sb and all other valuable members
I am in trouble.
I have a 1990 toyota 2.0D, with 2C engine. Engine has clocked 160k miles.
Last night while driving engine generated a strange noise, more like when u trigger self motor on a running engine. I checked oil and it was on Low line.
I checked again, engine was behaving erratically, with some time loud and sometimes mild knocking sound (karka).
Today i took it to mechanic, engine generates self motor sound if i drive it above 1500 rpm.
Mechanic said either there is some issue in cranshaft area, or head.
He thinks there is some "tikki" under the Glow Plug that falls in the cylinder.
We also removed all glow plugs, mechanic restricted glow plug hole with fingers one by one while running the motor on self.
3 cylinders were behaving alright, displacing his finger with a pop. BUt cylinder 1 had very less suction and was not displacing the finger.
I also checked, most of the time cylinder did not displaced my finger with pressure, but after a few turns it did displaced my finger.
What is you assessment??
Is this a valve job?
If i remove my head, what course of action/tasks you recommend to do in a go.
I would be grateful for ur guidance.
Regards, Ali
