Sorry to bother you again @Xulfiqar
Just got the car checked again with an OBD-II scanner. Once again, the scanner showed a different story altogether. The ESP error on the car had disappeared today (fishy). The car had two faults on the odometer display today...
1. SRS defective, visit workshop.
2. Speedtronic, drive to workshop.
Today the owner told me that the car has had two transmission replacements in the past including a cluster change as well. Due to the cluster change, the odometer currently shows 273xxx miles but the car has 123xxx KMs on the original odometer (his claim. I will check that as well). Is there a way to verify the car's mileage without using Star? Is mileage stored under the ICM option? The OBD-II I used showed everything from CANBUS to airmatic.
The OBD also gave the following errors...
1. Leak in airmatic system (the airmatic did raise and lower the car as needed. It did not give a "Stop! Car too low" indication. Does this mean that the pump and shocks are okay but there is a leak somewhere in the pipes?)
2. Leak in dynamic seat pneumatic pump.
3. Loss of pressure in dynamic seat bolsters.
4. Boost pressure sensor! Boost pressure too high/low or implausible.
5. Loss of communication with ICM.
6. Active service system not available.
7. The SBC pump was dead.
8. Front left wheel level sensor malfunction.
9. KEYLESS-GO AND PUSH START INOPERATIVE.
What I don't understand is that the airmatic on the car was working when I checked it and no indication on the dash. I pressed the raise button and it went up. The sport I and II settings did lower the car. Could all this be due to the CANBUS fault? Is the leak in the system; in the shocks or the pump itself? From what I understand, the car should not go up at all if the pump is weak and the whole car should collapse. Blown shocks also keep the car collapsed. Also, what would a front left wheel level sensor cost?
The massage function on the seats was also not working. No bolster inflation at all. The OBD said that there was a leak in the dynamic seat pneumatic pump. How much does this cost (in euros, pounds, dollars anything...)?
The car did not go past 3k RPM which was due to the boost pressure sensor I think. It went up till 60 MPH and then stopped accelerating. The AC threw no codes on the OBD and worked fine. I kept it on the whole time at low setting. The car did not overheat but did puff out black smoke when accelerating. Could this be due to a failing cat-con or bad quality diesel?
The owner still has the original odometer with him. If I put it back in the car instead of the present one, would it resolve the CANBUS error? How would I revert it to the original mileage?
Is there a way to repair the SBC? The error went away when you restart the car. The owner had also put in a new brake switch.
Could the keyless go and push start problem be due to the transmission swap? If the wiring were to be corrected, would it resolve the issue?
Awaiting your valuable response.
