I can give you contact of a person who can source you clean H22 H23 or F20B Dohc.
0334 5088180 sajid mithu khan saddar.
Broooo ļøļø
Use bit thick oil may be it will reduce this problem, try 5W40 engine oil. Donāt use thin oil like 5W30.
Definitely will move to 5:30 Actually Iāve recently switched to 5:20 shell from 5:20zic Chalo in any case thanks so much for all the help bro
Wonder whether the marking on these Dunlop tyres are legit or fake, the production date in my reckoning should be next to the DOT markings but there is a vacant space in between and the production date is to the further right. Got them from Quetta ...
Haha good one. Now he his legit to risk his life along with others when on the highway..hahaha....Adventures of Tintin ....
@Xulfiqar are these roller rockers or flat tappets?
Cam isn't visible in this pic
Dear Sirs, can normal (oil type) power steering be replaced with a electric one? Talking about civic 3rd gen cars. Will it fit on bolt or alteration will be required? What will be the impact on performance?
It's no issue if you used that wax. Nothing bad has happened to you car paint. You can regain the shine.
Just use another wax and you will be fine. I can recommend you soft99 kiwami as a cleaner wax. If you do not want a cleaner wax then try sonax high speed spray wax.
@Xulfiqar.
I want to know if there is any significant drawback of blocking the input air to the Air Assist Control Solenoid Valve. Car is accord cl9. I have read that it's function is to provide air to the injectors until the car reaches operating temp at which the valve seals the input port. Is there any other function of this valve?
This is to assist in atomisation of the fuel spray on a cold engine to help clean the tailpipe emmissions. It prevents bucking and rough idle on a cold engine also. Blocking it will just cause a slightly rough run when cold started and a bit more toxic exhaust - nothing more.
Thanks, brother. I recently ordered a Collinite 476, hopefully it will help, otherwise, I'll work upon your valuable advice. Thanks.
@Xulfiqar i have a Honda Civic which makes power steering whine only when it is started cold, after 5-6 minutes noise reduces that its not noticeable. What can be the reason?
Hey, i wanted to know which engine oil grade is best for 2016 wagon r? Currently m using total 10w40
you have a leak in the suction line from the tank to pump or your tank filter is partially clogged and not allowing thick/cold oil to flow.
I have replaced power steering pump as steering was feeling bit heavy and also cleaned out reservoir bottle with carb cleaner. Flushed out all old oil it was atf in it and poured fresh honda psf. Steering feels lighter, lets hope it stays light, whine free and leak free.
