AOA Bro. need help with one thing. i got a faulty catcon (broken/removed) from the housing on a 2015 civic r18z1.
now i have some options to go ahead with. replace it with a make shift steel mesh (Jali in local terms) life long solution. mostly will make the annoying noise go away however car will remain set at lean air fuel mixture since both oxygen sensors will have same value.
replace with chinese new cat con costing between 20-25k PKR.
replace with kabli japanese used replacement costing between 38-40k PKR.
what do u recommend?
