Any reliable mechanics for rebuild in Isb/Rwp?
@rajaatta
This is a cvt, why would you need to do that. What good could possibly come off of it
I have Honda Civic 2005 EXI PROSMATEC with D15Y3 Engine. I want to ask that is this engine comes with oxygen sensor?If yes then where it is located ?
O2 sensor(s) are part of exhaust system, it has 2 locations at catalytic converter depending upon engine. Post & Pre locations are marked in color. are vital for engine fuel efficiency.
@Hassan1991
It has fuel trim pot located behind the dashboard.
Sometimes a very weird loud noise comes out of my daihatsu cuore manual usually when car moves slowly after starting. The noise is just like an empty pet plastic bottle has been crushed by a car wheel. But when we look for such a bottle we do not find any thing means the noise has been made by car itself. As far as I guess It started occurring after an oil change about two months back maybe due to any oil priming issue or what else? Plz comment xulfiqar bhai?
please search & shuffle your cabin specially behind rear seat and inside wheel well , you may find culprit.
What is the name of this part? This part has broken during brake pad changing and allied service of Corolla 2007. Now could not find new in Karachi.
Apparently it is ok but whenever car goes on uneven road and brakes are applied, then rattling sort of sound is coming. Is it due to this missing clip or else?
What is the disadvantage other than sound if car keeps on driving this manner without this clip? 1 mechanic suggested to put Rubber tube piece or Sand-paper piece to avoid such sound, Will it be reliable solution?
This the clip used to prevent noise, but this also position the pads on the guide pins and piston. Not installing them can result in noise, a soft brake pedal and caliper damage.
My car gm6 city is leaking coolant from the expansion bottle. It is sort of droplets on lower shield and fan cover after every drive but the level in expansion bottle is always on up or above level. What may be the issue. I am attaching photos.
replace radiator cap @dms664
No need to worry, it does it when level is high. Person before you overfilled. It will stop itself when level settles
I was of the same opinion as I recently got this car. Lets hope for best. Thanks for kind guidance.
Sir car is only 17k driven. Can this be claimed in warranty if the cap is bad?
you can talk to dealership on your next visit.
Make sure its only filled between min and max on the bottle when cold, not to the top.
If its filled above max when cold, this will happen, some coolant residue is normal on the tank top as that is due to the breather vent. But it should not be vomiting coolant.
Thanks sirTotally agreed. The ex owner put the bottle level as such that at cold the level is at top line.
Ex owner needs to put down his meth..
He sounds like someone who follows, Bhar do, sabb bhar do, poora bhardo top takk.
This is why transmissions dont have dipsticks anymore. Owners doing crazy stuff.
