Thanks for the quote, so which wire you will recommend? along with plug because as you quoted that wires are not available? so what will be other option?
Regards,faizan Essani
You can select the required wire set from fairsale autos.They also have imported spark plug wires in stock.
bump
Any questions about spark plugs?just post them
bump bump
Dose changing spark plugs makes any difference in a car's fuel consumption..
In cars having efi engines,you can see a significant improvement in fuel consumption.The fact is that every thing is controlled electronically.If the crank gets a better push,the whole system will be electronically advanced.The unburnt fuel portion is decreased to a significant level.This is what we call "pickup" in simple words.You can get fuel efficiency improvement from 5% to 10%.You also have to use a better air filter,so that the engine is able to breathe properly and make the ignition process better.
what plugs do u recomend for alto carby 1000cc?
plugs for daewoo racer...??
The plugs for alto 1000cc are AUTOLITE platinum AP63.
The plugs for daewoo racer are AUTOLITE platinum AP63.
how much will they cost?its life?nd upto what extent performance is increased?
The price of AP63 is Rs.325.As daewoo racer engine is efi,you should feel better acceleration,smooth running.The life is 50,000 km(the calculation is based on engines using only petrol,it may differ in case of cng.)
can i use them in my bike??
I have ravi piaggio 125 CC .. If yes then cost?
The spark plug for ravi piaggio is XTREME SOPRTS IRIDIUM XS4163DP.The plug is for motorcycle use only.The plug is also recommended for honda 125.Price is Rs.650 per piece.
for daihatsu terios kid 1000cc 3 cyl.
The spark plug for terios kid are as follows;1.AUTOLITE PLATINUM AP39232.AUTOLITE XTREME PERFORMANCE IRIDIUM XP3923.
bro i need plugs for my vitz 06..what do u recommend?
