DO NOT USE type A fluid in a box designed for dexron spec. You can buy Dexron 3 spec fluid very easily in Pakistan, caltex, emarat, total, shell, Fuchs, ZIC etc all sell it.
For the magnets - they are to catch any ferrous particles in the transmission that are shaven off as regular wear. Some trans have them some dont, you can put one or two there yourself. Remove them from a hard disk. I did that on my Mercedes, it does not have magnets from the factory so I installed one.
Make sure you install it somewhere where it wont be near some other steel part - in my case the valve body is in 2 large parts, and one part is shallow so I stuck it on the pan in that vicinity.
