Sorry For Late Reply..Have Lost This Topic And Now Get Eye On It
Well I Have Sanyo 1 Ton Unit And Yes Its 2006 Manufactured And Yes Model Model Is SAP-124GHGC..Its With Heater Unit....!!
Well From Person I Have Bought.....He Was Quiet Old Friend Of Ours And He Confirmed Its of Singapore....!!He Suggest It Among All Units....Although Other Japanese Brands Are There Too National Panasonic Is made In Malaysia..Same Goes With Sharp.....!! Only SANYO National Panasonic And SHARP Are Brands Lies In A Class In Rotary Technology...General Is Also Best But Due To Piston Type Compressors...Which Last Looonger..But Heavy On Electric Bill.....!!
I Am Using Sanyo From Like 2 Months Almost And Its Working Ok.....!! You Just See The Outer Unit And Inner Unit Hows Its Built And You Know The Quality Difference B/w CHINA Korea And Japanese Brands...!!
LG And Hyundai Are Korean And Is Better Than Chinese Brands....Mr Slim Xtreme Is Also Chinese Assembled Now...
Sanyo Offers 1 Year Parts And 3 Years Compressor Warrenty....!! Same Goes With All Others Japanese Brands...!!
Its 1 Ton Outer Units Weights 40kg Itself....!! So You Need Good Support Angles To Mount It....!! 300rs Angles Just Don't Work On It...!!
I Myself Fully Satisfied With Sanyo....!! Since We Have Used It Earlier And Its Best In Its Class...!!
Fitting Also Matters Much....If Your Lines Are Extended Over 8ft.....You Need To Tapp Inn More Refrigerent In The Unit To Overcome The Length Difference...!! Mostly People Don't Do This And Result Is After Some Time...Low Cooling And Loads On Line And Later It Leaks Out...!!
So Keep This Thing In Mind Too...!!
