Thank you for the sensible advice. Distilled water obtained from condensation outflow pipes on air conditioners is quite good. Millat also uses thicker and fewer lead plates for UPS batteries which alongwith the debris traps extends their usable life. It is wise never to let a battery discharge completely and not to let it overcharge either. Good UPS systems regulate charging rates from fast when the battery is low to a trickle when it is nearing full charge. Where can one buy Pyro Battery Electrolyte 12:50, is it easily obtainable?
[QUOTE=imranbhatti;335229)
U may Choose any brand as per ur satisfaction but i will recomend u to buy battery without electrolyte & put some good brand sealed electrolyte( I use Pyro Battery Electrolyte 12:50 SG already maintained) & fill precisely to the Lower Electrolyte level]
