So much talk about grades and what is current and what is not. CI4 is not latest standard for deisel its CJ4 but take a closer look at the fuel types. I'll list them for you.
CI-4 is Current Introduced in 2002 for high-speed four-stroke engines. Designed to meet 2004 exhaust emission standards implemented in 2002. CI-4 oils are formulated to sustain engine durability where exhaust gas recirculation (EGR) is used and are [U]intented for use with diesel fuels ranging in sulphur content up to 0.5% weight[/U]. Can be used in place of CD, CE, CF-4, CG-4 and CH-4
If I were you i would look for CF on the box and here is why
CF is also current and Introduced in 1994 for off-road, indirect-injected and other diesel engines including those using fuel over0.5% weight sulphur. Can be used in place of CD.
I Haagen to own two land cruisers 1998 and 2006 and using Shell Helix Ultra in both ever since it was introduced in Pakistan. 0 smoke and amazing mileage and you can hardly tell if the engine is running or not.
