TBH never ending debate
Keeping using it, just make sure you get a original one every time.
Works good for me.
I changed my car oil from Makki oil store akbar chowk lahore Our all cars are going to same place for decades I am sure that they don’t compromise on quality Infact I also suggest other to go there because of owner hospitality and quality check
Also plz tell me about catalytic converter if this car has one
Guys, i couldnt find the right thread for this question so im asking it here. A friend has a 2010 Xli and his car doesnt start sometimes and sometimes it starts. The not starting issue is random, could happen anywhere anytime. Everything else is fine on the car and been maintained very good considering its 10 years old. Would appreciate if someone could point out the issue.
I also have a similar problem After having a comfortable ride when I park it so after 5-15 minutes when I again try to start car it does not startBut it starts when I put my car in gear and then push the key And sometimes pushing the car after lowering handbrake Could prove fruitful Otherwise when car starts you can take it to any corner of the country
Have your friend got the fuel pump of his car checked from any reliable mechanic?Because of the quality of the fuel available in Pakistan, it is highly likely that this is the problem with the fuel pump that is causing this trouble.
Hope it helps.
You can check this thread for details about the catalytic converter.
Yes i will tell him to get fuel pump checked. Is there an issue of the starter not working properly on this particular generation of Corolla? Have heard this issue from alot of owners of 10th. gen Corolla.
Perfect and Bravo! MA SHA ALLAH
Brother, continue using the same engine oil brand and grade, i.e. Caltex / Havoline 20w-50, which you are currently using in your ride.
Good luck!
Please re-upload the picture, or pic showing the front and back of engine.
And tbh, I have no idea, I can just guess, but if you upload the picture, I may be in a better position to give my opinion.
And the engine bay looks neat and clean MA SHA ALLAH...
Havoline 10w-30 is a great oil!
I wish, they introduce 5w-30 here too.
The best would be, if he gets his vehicle scanned via OBD Tool, for any problem.
2ndly, to me, fuel supply seems to be the culprit, still, unless / until proper diagnosis is made, one cannot confirm about the exact problem.
Thanks alot Basit Bhai
Thanks
Honestly speaking, I can't say anything about this for sure.
However, if the car of your friend has a starter problem, then this issue should be more frequent rather than random, so for now, I can suggest your friend to get his car checked from a reliable mechanic and he can get to the root of the problem.
Thanks alot brother!
My pleasure!
It's fuel pump.
