Received AFPR, @ser_gtr can you explain what is upper value for?
should have checked FPR first, it already has 3 hoses 1=in, 1=out and one for vacuum, i was rather having some other in mind!
So the pipes have been identified Do get the afpr installed before changing the lines and post the results.
Here's how the Tomei afpr works.
(Y)
Asked a kharadia to make something like this, which will go into fuel rail and have hose for pipe on the other end for connecting AFPR
Or You Can Also Try Using It With Same FPR...Just Remove Vacuum Line....FPR Will Serve As Adopter...
Else Fabricated Adopter Will Be A Good Thing...Just Make Sure He Do Groove And O Ring Same As Needed...Else It Can Leak...
Inlet hose being fabricated:
abandoned very rare 2 door Ae70's car was just having a dent on door and now its staying here for four years, dash is still good
final product :
Comparison
AFPR
Set at 3.5/4 bar OR 50~56 psi
a little test video, sorry for RPM for not being correct
EE80 / AE80 Blacktop test after AFPR | Tune.pk
Done same
Using 110 LPH walbro (since i reverted due to fuel lines) i donot understand one thing, pick is became much better than before but first gear locks around 50, second gone to 120 on latest test but it wasnt locking rather at 120 it was like very little feeling of fuel being stalled
That Can Be Anything Else Also...Its Not Fuel Everytime...If Pressure Is Maintaining In Rail......On WOT It Tends To Go Down But Not So Much....And Don't Always Go Hitting Limiter All The Time....You Will Be Done With Oil Rings Pretty Soon Else....
Just Make It Go Till 7k-7.5 Maxxx....Don't Be So Harsh On Them...Fuel Req Of These Are Quiet High So Take Care Of It
good going bro.
BOL with finalizing the swap and than go for some detailing to give it proper mean look.
these were knows as "LONDON" models
ahan
On my daily routing ,i am a very 'slow' type driver, its sort of a benchmark, i am very easy on throttles, believe me
I am sending my injectors for ultrasonic cleaning, lets see what are the results!
thanks man, will do it afterwards IA
some of them were also having sunroofs, this beauty is ruined though, ill check if i have earlier pics of this car
That's Good Thing....Don't Drive It Like Its Stolen
Injectors Sometimes Need Cleaning...Try It
B.t.w I Like That Ting Ting Chimes Of Old 86 Above 100...
