People Are Able To Do That.....They Can Be Skillful ...Thing Is No One Pays proper Attention....Motors Are Precisely Builds With Calculations Done In Thousands Of Mm...Here No One Goes Above Vernier Caliper And 40# Raigmaal
Cylinder Honing Bore Check Rings Piston Size Calculation Valve Seat And SO Many Things Are Involved......No One Use Torbque Wrench...No Concept Of New Head Stud ...Reusing Stretched Studs And Then Crying When You Blow Gasket...!
Rebuilding It All On Dirty Place Full Of Dust ...No Concept Of Using Engine Stand Cleaning ......
Engine Rebuild Is Basically An ART Which Only Few Understand .....It Need You To Be Close To Perfect ...Rebuild Motors Long Another 300k Miles But Point Is ..If Done As It Should Be....!
OE Parts Availability Is Also A Biggest Issue....Fakes And One Important Cheap Replacements Can RUIN Your Entire Rebuild....! And In End...People Want To Get Cars Fixed At Cost Of Cycle.....And This All Wont Come Cheap....!
