should i replace the 2 point with orignal oem ones or get the 3 or 4 pin/point plugs :S
will the 3 or 4 point ones cause an issue ??
try getting 2 tip ones in same specs as i did and i am quite satisfied
thanks man! wat did u get can u temme please!
wich plugs u usin man !!!
try getting ur throttle body serviced and ur fuel filter changed! it shud solve ur problem! tumari car kitni km chal chuki hai?
the same i did with my nissan sunny, 2005 and the remedy was just getting same NGK plugs of course upgraded version of Platinum series but the series should be the same as stock were BKR5E NGK i got BKR5E Platinum NGK.
nice! oh man ma car is driven 58200km only! the previous owner cng'd it at 34000km! ill get the fuel filter cheked! i got throttle body fixed!
help any 1 ?? any suggestions
i am about to get the 4 tip bosch plugs! any suggestions or comments :S
will the plugs change need separate wires???? i mean shud i get the plug wires changed as well ??
