Its not a nice feeling to be second-guessing oneself, is it?
Itni mehnat karnay k baad one suddenly fears that maybe the system still isn't performing well...
Tripping of AC is not to be taken as a benchmark. Of course with Lahori heatwave I wouldn't expect it to cool down to a level that would bring evaporator to near freezing temp or inside cabin temps low enough for that other sensor to do that job indirectly. If you can, post manifold readings, line temperatures and conditions when they're taken so we can do a proper comparison.
One thing I've noticed is critical: When everything else is almost the same, its the airflow across the condenser (fast fans) that enables proper cooling; with fans at half speed the system has just too much heat in itself to do any noticeable cooling. And then also if the weather outside is like in the 42+degC then I think it would be injustice to expect it to perform as it would in 33degC ambient.
I'm thinking to put the clear anti-UV film on all windows from the outside (except front windscreen). IMO even if it lasts just one season then its worth it. I'm also considering reinforcing roof insulation.
