Guys got a problem with my Corolla Gli AC system and need your expert opinion about it.
A month ago my Corolla Gli's AC stopped working and only warm air started to come out. It's a 2010 model 1.3L version and AC has been working flawlessly uptil recently. Thought it ran out of gas so went to a local AC technician who I usually get my mehran AC serviced from and got complete service/cleaning and refill of gas. AC started working well although I felt a bit less cooling than before.
About a week later AC started throwing warm air again and I went to the same AC guy and he filled in a little bit gas again and told me that the compressor sensor is faulty and I should get it checked from Toyota 3S dealer. Went to Toyota Garden Motors and the technician told me after looking at the glass on the AC pipe that there is carbon in the system and that I'll have to replace every part of the AC system or else the issue won't get resolved. I was shocked to hear that everything would cost 70-80K and that there is no other solution.
I went to another local AC technician to get a third opinion and after checking in detail he said there is no carbon in system and that there might be moisture in the system and that the previous technician might not have properly vacuumed the system. He serviced the AC system again and sucked out everything from the system with a vaccum pump. Then filled with gas and everything started working again and AC started chilling as it used to before this problem occurred so I thought maybe the issue is resolved. The guy told me that if this issue comes back then either there is a leak in the system somewhere or the compressor is weak. And these made sense to me.
After a few days the same problem persisted and warm air was thrown out by AC. I did a bit of testing myself and I think the compressor might be faulty as when it turns on the AC starts to chill very good and when it doesn't the AC throws warm air. I've also noticed that when I turn on the AC and it starts to chill, if I put the blower at full speed the AC keeps chilling, but if put at 1, 2 or 3 the AC chills for a while until the compressor trips and then sometimes it starts chilling again but mostly it just throws warm air especially when car is moving but when slowed down or stopped it turns back on again. Don't know if this behavior is normal for a faulty compressor or something else might be faulty as well?
Please provide your insight and solution, thanks.
