Well here's the trick with KSG:
The first thing you wanna do is pour some into a smaller spray bottle, just makes using it easier, I use an old 4 oz Griot's Garage spray bottle. Then fill a small bowl with water to dunk your cotton or mf square applicator in. Dunk the applicator in there and wring it out real good so it wet but not soaking, this makes spreading the product a lot easier. I usually dunk and wring about 3x's during the process. Now as far as spraying the product onto the applicator, one little squirt is enough to do an entire fender or half a hood/roof/trunk, in the case of this product, less is more! Once you apply it to the area, go over it up and down and sideways with the 1 spray to ensure complete coverage and once done go ahead and grab your mf towel and remove it, no need to wait for haze. If for some reason it does haze and its hard to remove, no problem, just grab some QD, spray it on there and wipe off. If it doesn't haze and its hard to remove your either using too much product or maybe your applicator is getting dry. Once done you'll notice the great clarity in your paint, provided the prep work was already done and/or the paint is in great shape. Now here's the thing with KSG, go back over the car 12 hrs later again with the same process and look out!! The shine then pops even more and another coat of protection to boot.
Sent from my iPhone using Tapatalk
