So continuing to my prior teaser of showing the bottles of werkstat range. Here are the results with the routine I followed:
Friday night (2-3 hours)
1. Washed the car with turtle ice shampoo
2. Clayed the car with the yellow poly elastic clay. My first experience with the clay. I had cut a small 1/4 piece from the bar and utilising the stretching ability of poly elasticity without crumbling, I used that to clay the entire car.
Saturday morning (3-4 hours)
3. Paint prep using WERKSTAT ACRYLIC PRIME (chemical cleaners to remove prior layerings of wax, tar, sap, etc. So wipe the product in with pressure that cleanses and also has polishing (non abbrassive) agents for bringing out the ultimate flake pop, reflection and removing some imperfections. I also did all car windows with this which worked excellent and made the glass super slick.
This is how the pad looked after this step (and both sides looked the same, just had one MF pad
This was immediately followed by a layer of sealant, WERKSTAT ACRYLIC JETT. Applying this sealant is a real ease. Just spray on a panel and using the MF towel spread the product, switch to a dry MF and buff it out (no powdery residue). So takes about 20 minutes to do the whole car.
I applied 3 coats of this with an hour of cure time in between (the product bottle says 30 mins though). Applying these additiona 2nd and 3rd coat just brought the result to a different level MashAllah. I was doing this all alone and weather was pretty humid so didn't take pictures in between.
Once i was through with sealant, I then applied ACRYLIC GLOS to finish things off. This is a quick detailer with a good concentration of sealant and gloss.
Here are the results MashAllah (pics taken in the evening after the sun was almost gone with google nexus phone) :
The full look:
Side pose
Yet another side pose
The surface was super slick
I then went out (where I met @durrani_45 as well) and after that to the market and this is how it looked from a distance at 9pm in the dark:
And there came what always comes when you have spent this much time on the car. Aandhi toofan followed by rain but then that also gives you a chance of water beading (although because of the toofan the surface had become dusty but still looked great beading, even on the glass as well ):
So thats about it for the detailed writeup.
