Apply on a panel & with same pad keep cleaning & keep spraying water until it washed out with water
Use same pad for next panel with same procedure
Do panel by panel & at the end clean your ride with damp Mf or you can even wash If you want
Dry F1 can produce swirls , keep her wet
Consider your F1 as pre cleansing or compounding, now Yes you can use GC for glazing , just remember glazing is opposite to waxing , you glaze on virgin surface usually after cleansing or polishing , so no Kunjosee , dry pad koo nahee ragarna
Throw some glaze on ride & also some on pad , on pad with finger spread it evenly , then glaze with every possible motion & direction & than wipe off
Now you can use 26
Hopefully works
